Full charge at 7am down to 63% at 11 am.How drained is your battery? It's kind of a relative measurement. If you phone have been unplugged for 10 minutes, is at 99% charge, then you are talking about a very minimal amount of usage by bluetooth in the grand scheme of things.
zte warp 7, hwatch is up to date, I am using a watchmaker face time,date,temp digital. I am going to change to a stock watch face and uninstall watchmaker, I will let you know if this solves the problem. Thanks for your help and input.What phone? Is the Huatch up to date? Was this after an initial set up or following a factory reset? Are you using anything like Watchmaker faces? I only ask the last one as my watch didn't get along with some of the faces from that app.
NOTE: I am also using an app Feel The Wear. Has anyone had any problems with this app using excessive battery?zte warp 7, hwatch is up to date, I am using a watchmaker face time,date,temp digital. I am going to change to a stock watch face and uninstall watchmaker, I will let you know if this solves the problem. Thanks for your help and input.
I've heard people claim that causes battery problems, but that would be on the watch, not your phone.NOTE: I am also using an app Feel The Wear. Has anyone had any problems with this app using excessive battery?
What version of Bluetooth does your watch use? I've heard that the newer v4.1 drains less battery than the v4.0
uninstalled watchmaker did not fix problem. Uninstalled feel the wear battery back to normal. shame i really liked this appI've heard people claim that causes battery problems, but that would be on the watch, not your phone.
using 4.1 watch, marshmallow 6.0, newest update of android wearWhich 3rd party watch app do you
