mxrider108
I am developing an application which uses Bluetooth to connect to a device and send/receive data. I am doing all of my testing with a Nexus One phone.
I have never been able to establish a SPP (serial port) connection from my phone to any device. However, I have been able to connect from a device (my laptop) to my phone using a Mac equivalent of PuTTY (The only exception to this is the "Bluetooth File Transfer" app from the Marketplace seems to work, but I don't think that uses RFCOM/SPP...).
I keep seeing this message in my LogCat logs:
as well as these:
I have tried using the UUID of "00001101-0000-1000-8000-00805F9B34FB" and I have also tried using the:
method instead of
as well--with no luck.
I am using the BluetoothChat example and variations of that code to do all of my testing...
Solutions or suggestions would be great...or even a better/less complex example of some testing code I can run on the phone, or a python script or something I can run on my computer to help debug?
Thanks! I hope this isn't a bug with the Android OS, but if it is I hope to find a workaround.
I should also note that most devices show up as "paired, but not connected" in the Bluetooth settings
Code:
ERROR/BluetoothService.cpp(78): stopDiscoveryNative: D-Bus error in StopDiscovery: org.bluez.Error.Failed (Invalid discovery session)
as well as these:
Code:
java.io.IOException: Operation Canceled
java.io.IOException: Software caused connection abort
Code:
Method m = device.getClass().getMethod("createRfcommSocket", new Class[] { int.class });
sock = (BluetoothSocket) m.invoke(device, Integer.valueOf(1));
method instead of
Code:
device.createRfcommSocketToServiceRecord(UUID)
