Apps Bluetooth connection in activity and fragment
systx
I have android project, to control led on my arduino.
DeviceList.java
Code:
        package com.led.led;
    import android.content.Intent;
    import android.support.v7.app.ActionBarActivity;
    import android.os.Bundle;
    import android.view.Menu;
    import android.view.MenuItem;
    import android.view.View;
    import android.widget.AdapterView;
    import android.widget.ArrayAdapter;
    import android.widget.Button;
    import android.widget.ListView;
    import android.bluetooth.BluetoothAdapter;
    import android.bluetooth.BluetoothDevice;
    import android.widget.TextView;
    import android.widget.Toast;
    import java.util.ArrayList;
    import java.util.Set;
    public class DeviceList extends ActionBarActivity
        //widgets
        Button btnPaired;
        ListView devicelist;
        //Bluetooth
        private BluetoothAdapter myBluetooth = null;
        private Set<BluetoothDevice> pairedDevices;
        public static String EXTRA_ADDRESS = "device_address";
        @Override
        protected void onCreate(Bundle savedInstanceState)
            setContentView(R.layout.activity_device_list);
            //Calling widgets
            btnPaired = (Button)findViewById(R.id.button);
            devicelist = (ListView)findViewById(R.id.listView);
            //if the device has bluetooth
            myBluetooth = BluetoothAdapter.getDefaultAdapter();
            if(myBluetooth == null)
                //Show a mensag. that the device has no bluetooth adapter
                Toast.makeText(getApplicationContext(), "Bluetooth Device Not Available", Toast.LENGTH_LONG).show();
                //finish apk
                finish();
            else if(!myBluetooth.isEnabled())
                    //Ask to the user turn the bluetooth on
                    Intent turnBTon = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
                    startActivityForResult(turnBTon,1);
            btnPaired.setOnClickListener(new View.OnClickListener() {
                @Override
                public void onClick(View v)
                    pairedDevicesList();
        private void pairedDevicesList()
            pairedDevices = myBluetooth.getBondedDevices();
            ArrayList list = new ArrayList();
            if (pairedDevices.size()>0)
                for(BluetoothDevice bt : pairedDevices)
                    list.add(bt.getName() + "\n" + bt.getAddress()); //Get the device's name and the address
            else
                Toast.makeText(getApplicationContext(), "No Paired Bluetooth Devices Found.", Toast.LENGTH_LONG).show();
            final ArrayAdapter adapter = new ArrayAdapter(this,android.R.layout.simple_list_item_1, list);
            devicelist.setAdapter(adapter);
            devicelist.setOnItemClickListener(myListClickListener); //Method called when the device from the list is clicked
        private AdapterView.OnItemClickListener myListClickListener = new AdapterView.OnItemClickListener()
            public void onItemClick (AdapterView<?> av, View v, int arg2, long arg3)
                // Get the device MAC address, the last 17 chars in the View
                String info = ((TextView) v).getText().toString();
                String address = info.substring(info.length() - 17);
                // Make an intent to start next activity.
                Intent i = new Intent(DeviceList.this, ledControl.class);
                //Change the activity.
                i.putExtra(EXTRA_ADDRESS, address); //this will be received at ledControl (class) Activity
                startActivity(i);
        @Override
        public boolean onCreateOptionsMenu(Menu menu)
            // Inflate the menu; this adds items to the action bar if it is present.
            getMenuInflater().inflate(R.menu.menu_device_list, menu);
            return true;
        @Override
        public boolean onOptionsItemSelected(MenuItem item) {
            // Handle action bar item clicks here. The action bar will
            // automatically handle clicks on the Home/Up button, so long
            // as you specify a parent activity in AndroidManifest.xml.
            int id = item.getItemId();
            //noinspection SimplifiableIfStatement
            if (id == R.id.action_settings) {
                return true;
            return super.onOptionsItemSelected(item);
ledControl.java
Code:
    import android.bluetooth.BluetoothSocket;
    import android.widget.SeekBar;
    import android.app.ProgressDialog;
    import android.os.AsyncTask;
    import java.io.IOException;
    import java.util.UUID;
    public class ledControl extends ActionBarActivity {
        Button btnOn, btnOff, btnDis;
        SeekBar brightness;
        TextView lumn;
        String address = null;
        private ProgressDialog progress;
        BluetoothSocket btSocket = null;
        private boolean isBtConnected = false;
        //SPP UUID. Look for it
        static final UUID myUUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB");
        @Override
            Intent newint = getIntent();
            address = newint.getStringExtra(DeviceList.EXTRA_ADDRESS); //receive the address of the bluetooth device
            //view of the ledControl
            setContentView(R.layout.activity_led_control);
            //call the widgtes
            btnOn = (Button)findViewById(R.id.button2);
            btnOff = (Button)findViewById(R.id.button3);
            btnDis = (Button)findViewById(R.id.button4);
            brightness = (SeekBar)findViewById(R.id.seekBar);
            lumn = (TextView)findViewById(R.id.lumn);
            new ConnectBT().execute(); //Call the class to connect
            //commands to be sent to bluetooth
            btnOn.setOnClickListener(new View.OnClickListener()
                @Override
                    turnOnLed();      //method to turn on
            btnOff.setOnClickListener(new View.OnClickListener() {
                @Override
                    turnOffLed();   //method to turn off
            btnDis.setOnClickListener(new View.OnClickListener()
                @Override
                    Disconnect(); //close connection
            brightness.setOnSeekBarChangeListener(new SeekBar.OnSeekBarChangeListener() {
                @Override
                public void onProgressChanged(SeekBar seekBar, int progress, boolean fromUser) {
                    if (fromUser==true)
                        lumn.setText(String.valueOf(progress));
                        try
                            btSocket.getOutputStream().write(String.valueOf(progress).getBytes());
                        catch (IOException e)
                @Override
                public void onStartTrackingTouch(SeekBar seekBar) {
                @Override
                public void onStopTrackingTouch(SeekBar seekBar) {
        private void Disconnect()
            if (btSocket!=null) //If the btSocket is busy
                try
                    btSocket.close(); //close connection
                { msg("Error");}
            finish(); //return to the first layout
        private void turnOffLed()
            if (btSocket!=null)
                try
                    btSocket.getOutputStream().write("1".toString().getBytes());
                    msg("Error");
        private void turnOnLed()
            if (btSocket!=null)
                try
                    btSocket.getOutputStream().write("2".toString().getBytes());
                    msg("Error");
        // fast way to call Toast
        private void msg(String s)
            Toast.makeText(getApplicationContext(),s,Toast.LENGTH_LONG).show();
        @Override
        public boolean onCreateOptionsMenu(Menu menu) {
            getMenuInflater().inflate(R.menu.menu_led_control, menu);
            return true;
        @Override
                return true;
        private class ConnectBT extends AsyncTask<Void, Void, Void>  // UI thread
            private boolean ConnectSuccess = true; //if it's here, it's almost connected
            @Override
            protected void onPreExecute()
                progress = ProgressDialog.show(ledControl.this, "Connecting...", "Please wait!!!");  //show a progress dialog
            @Override
            protected Void doInBackground(Void... devices) //while the progress dialog is shown, the connection is done in background
                try
                    if (btSocket == null || !isBtConnected)
                     myBluetooth = BluetoothAdapter.getDefaultAdapter();//get the mobile bluetooth device
                     BluetoothDevice dispositivo = myBluetooth.getRemoteDevice(address);//connects to the device's address and checks if it's available
                     btSocket = dispositivo.createInsecureRfcommSocketToServiceRecord(myUUID);//create a RFCOMM (SPP) connection
                     BluetoothAdapter.getDefaultAdapter().cancelDiscovery();
                     btSocket.connect();//start connection
                    ConnectSuccess = false;//if the try failed, you can check the exception here
                return null;
            @Override
            protected void onPostExecute(Void result) //after the doInBackground, it checks if everything went fine
                super.onPostExecute(result);
                if (!ConnectSuccess)
                    msg("Connection Failed. Is it a SPP Bluetooth? Try again.");
                    finish();
                else
                    msg("Connected.");
                    isBtConnected = true;
                progress.dismiss();
When connection is successfuly opens ledControl.java. I like to create new fragment which will be open from ledControl. Now i like to know how can i get bluetooth connection from ledControl activity and control new led from this fragment? I need on fragment only on/off button and Bluetooth connection to comunicate with android.. Please if anyone can help me?
ex:
i need some like this in my Fragment.java
Code:
                @Override
                @Override
            if (btSocket!=null)
                try
                    btSocket.getOutputStream().write("3".toString().getBytes());
                    msg("Error");
            if (btSocket!=null)
                try
                    btSocket.getOutputStream().write("4".toString().getBytes());
                    msg("Error");
