lunatic59 Moderati ergo sum Moderator Sep 12, 2017 #2 You put the device into pair mode and then on your phone you search for it in settings>bluetooth>search.
bhaskarb1262 Lurker Sep 12, 2017 #3 lunatic59 said: You put the device into pair mode and then on your phone you search for it in settings>bluetooth>search. Click to expand... Unfortunately Bluetooth unpaired need help 're connect
bhaskarb1262 Lurker Sep 12, 2017 #4 Unfortunately my blutooh unpaired how to connect 're paired my phone samsung j5 prime
lunatic59 Moderati ergo sum Moderator Sep 12, 2017 #5 So it's not unpaired? Just disconnected? You could try to forget the existing connection and re-pair it.
