Hi, I have a Droid Incredible and just bought a new Motorola HX550 headset to use with it. When using the Google Navigation feature (A2DP compatible), the first few words/syllables of the navigation are cutoff so I only hear the end of the instruction. Of course if the begging words are turn left or right, and I don't hear that part, it can make navigation a bit less than useful
But I'm trying to find out if anyone knows if this is an official Android issue? Or is this a headset specific issue?
I'm having a hard time tracking down much information on the issue, but did see a couple things on the Google forums that made it appear it might be a 'bug' with Android. But it's unclear.
- Does anyone have a bluetooth headset that definitely works with Google Navigation withOUT any delays/lags/cutoff?? If so, what model?
Thanks!
Thanks!
