Bluetooth headset on a droid problem
mega32
Hi , I am new to Android OS
I just got a Motorola Milestone and it is paired to a Motorola S9-HD.
I can control the music player on the Milestone without any problems ;
pause ,>> ,<< ,volume (need to adjust the master volume at the side of the phone)etc.
But when the player is pause , if i turn the power off on the S9-HD headset, the Milestone will automatically un-pause the song and plays it thru its built in speakers (which is loud if the master volume on the phone is adjusted to max).
Please help, it is very embarrassing when this happens in a crowed train.
Is it my fault or the os fault ?
It never happened when I was using the headset with the SE K850.
I don't know if what I wrote can be understood, sorry.
My Bad :p It looks like the fault is mine.I was fiddling with the phone, it hang and I had to do a hard reset (remove battery) And after charging the battery full I tried to simulate the the problem I face before and the the problem was solved.:confused: Sorry !:(
Darn it happened again. I realize that this happens when the screen is in sleep mode and if the bluetooth headset has paused the player if the bluetooth is turned off the player will un pause and player thru the speakers :mad:
