the only way I know is to install an app that will share files. Like i use File Manager.
with that you just find the ringtone file and long press and tap send to then tap bluetooth
If the ringtones are "protected content" (DRM), you probably won't be able to transfer them off the phone. When you purchase a ringtone, you are generally purchasing a license to "use" the ringtone, not to share it.
