I have about 10 different bluetooth devices paired to my phone. I have a Garmin navigation system, a car audio device so I can listen to music stored on my phone through my car stereo. I also have a bluetooth head set and even a stereo at work and also 2 different a2dp units in my home.
Currently the only way I know to switch between bluetooth devices is to open my settings, shut blue tooth off. wait a few seconds, then turn bluetooth back on and select the device I want to connect to. Sometimes this works, but often it attempts to connect to something that isnt in the area. If I have two or three devices that are in the area, often it will connect to what I dont want it to connect to.
Is there some type of bluetooth manager that would have all my devices listed and I could just select what I want to connect to, and if previously connected it will automatically disconnect what is was previously connected to and establish a connection to what I selected?
Also, is it possible to connect to two or three devices at the same time? As an example, I want to connect to my car garmin gps unit, but I also want to listen to my music through my car stereo bluetooth. Is there a way to do this?
Thanks for any advice / help
