My S6 is running Nougat, I'm on EE network in UK.
I recently received a security update. Since then, my phone won't connect to my Toyots Auris for media output. It was working fine before this update. It will connect for phone calls. But when I turn my car to Bluetooth input, the car screen is stuck at "loading".
The phone does output media to another device, but not the car.
I have researched this on web, tried re-installing the Bluetooth, clearing caches, nothing seems to work.
On Samsung "smartthings" app the phone shows audio output as "paired", the button for "set as media output device" is greyed out and doesn't do anything,
The Bluetooth settings section of the phone has the media output enabled.
Any advice gratefully received. Thanks.
