Bluetooth problem is a common occurrence post Android 8 Oreo update
john gter
2019-04-25 19_44_28-[Solved] Problems You May Encounter for Android 8 Oreo Update- dr.fone.png
Bluetooth problem is a common occurrence post Android 8 Oreo update how i can fix it please some one help me.
Your screenshot shows a paired and connected BT device called "MDR-XB95081" , whatever that is? A muffler bracket for a '78 Pinto?
So what's the actual problem, if any?
