Help Bluetooth remote shutter for U11
Dear All,
I'm a new member here.
My problem is the following:
I badly need a bluetooth remote shutter that REALY WORKS with the camera of my U11.
When I push the button on any of the two remote devices I own in order to take a photo, the CAMERA IS ZOOMING IN, but nothing else happens.
I tested the bletooth devices with more than twenty people's (family members, friends etc.) Android phones (many brands, but none of them was HTC) and all of them worked fine.
Is there a dedicated remote for the HTC U11?
I wouldn' like to switch to another phone because apart from this problem it's OK and the camera is excellent, way better than most of the other phone's.
Thanks for your help in advance.
Dear All,
Hi,
It sounds like the remote shutter devices you have are not compatible with the HTC U11 camera. Unfortunately, there may not be a dedicated remote shutter specifically made for the HTC U11. However, you may want to try using a third-party camera app that supports remote shutter control via Bluetooth. There are several available on the Google Play Store. Additionally, you can check with HTC support for any possible solutions or workarounds for this issue.
