Using ZTE Valet, I was able to set a bookmark, but try as I may I cannot add a second one. The url field goes blank and if I manually type something in while in the bookmark panel I just go to site.
I'm not really familiar with the stock browser, so I can't help you with that. But, you might want to try Dolphin Mini. Simple, fast and very easy to navigate. I use Mini on all my devices.
Thanks, I did manage to get the bookmark function working in mobile folders. Not sure if my model lets you create a sub folder, but probably don't need to do that.
