Help Bookstore unavailable after importing ePub
jeth32
I converted an HTML file to ePub using Calibre. The conversion appeared to go OK and the file read properly on the PC with the Calibre reader.
When I copied it to an SD card and imported it to my Novel things went awry.
The novel has been updated with the official upgrade from the Pandigital site to provide an Android menu initially with a link to the original B&N-type one on that first page.
However, after importing this ePub file, when I click on the B&N onject, I briefly see the B&N menu, but then it quickly reverts back to the first Android one before I can select the new book to open it.
The only way I can get the Novel back in working order is to connect it to my PC, manually remove the new ePub file, and then use the reset option to restart the Novel.
