I bought this phone about 2 weeks ago and have been trying to disable the bloatware as it seems to have a lot of it. However I think in doing so, I have broken the MMS settings on my warp 7 as it will not send or receive MMS messages. Text sms works fine as does calling and internet data.
I read that I need to change the APN settings to fix it.
Would someone with a BOOST WARP 7 N9519
mind posting their working settings ?
these are my current settings and are the current default settings since the new update yesterday.
SETTINGS>MOBILE NETWORKS>ACCESS POINT NAMES
Name
Internet
APN
n.boost.ispsn
Proxy
not set
Port
not set
Username
not set
Password
not set
Server
not set
MMSC
not set
MMS Proxy
not set
MMS port
not set
MCC
310
MNC
120
Authentication type
None
APN type
default,mms,hipri
APN protocol
IPv4/IPv6
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
LTE
MVNO type
None
MVNO value
Not set
EDIT *************************************************
The APN settings were correct as above.
The problem was in some app, not sure which one , but I was able to fix this issue by going into
SETTINGS>APPS>
then from the menu selecting
Reset app preferences
Now everything works again.
Name
Internet
APN
n.boost.ispsn
Proxy
not set
Port
not set
Username
not set
Password
not set
Server
not set
MMSC
not set
MMS Proxy
not set
MMS port
not set
MCC
310
MNC
120
Authentication type
None
APN type
default,mms,hipri
APN protocol
IPv4/IPv6
IPv4
APN enable/disable
APN enabled
Bearer
LTE
MVNO type
None
MVNO value
Not set
SETTINGS>APPS>
