Root [Boost Mobile] Attention!!! NF4/OA3 users
What theme? comment features... also if you want combination theme comment
  • Total voters
    8
  • Poll closed .
6th_Hokage
I am thinking of making a Custom TW NF4/OA3 rom but unlike most Developers, before going public I would like your input on what theme/Features you guys would like then I'll check the available mod sections to see if it's realistically possible, obviously I'll rank theme/features based on how many ask for said thing...if i can't make said rom fast enough by myself I'll ask other tech nerds with the Sph-L710T for help and maybe make a team if possible....
I also switched to TWRP. No problem at all. How do you plan to make your ROM different from wicked x?
well for one it will be based off of NF4....and later OA3 once it get's captured...and the idea is similar to Wicked X Barebones just since I'm not a member it won't have the logos and stuff....but i plan to make it as bloat free and as small in size as possible...but like i said I'm currently looking for team members (at the college i attend) since after looking at the code it's gonna be a big project...since I'm new to the Dev side...
I am learning code. I don't know jack but I would like to embark on this journey.
I TOO WOULD BE GLAD TO LEND A HAND AS A TESTER... im not a dev or anything but im not stupid and have basic knowledge and common sense on how things should work..along with pretty good problem solving skills....
also would lke to add i have taken the 0a3 update and would like to add that i only use philz and the flashing of twrp was not needed on any of the phones i used..... i odin'd philz rooted and then installed wicked s5 xperience v2.2 and all is good have not had no issues
I cant find the OA3 Stock unrooted rom. I wanna unroot return to stock and take the update. Im on the sph l710t 4.4.2 OA3 baseband. Anyone help with a link to the stock unrooted OA3 ?? Direction with stock recovery everything so i can take this annoying update n re-root. Been seaching n cant find the file. Any help please n thank you
If you just don't want the annoying update, just pull down and long press on the update, then press app info, then uncheck notifications and all gone.
