So I managed to get my rooted s3 on 4-11 LA DEATHLY KERNEL to get into bootloop. I'm still able to get into download and recovery but wanted to ask what I should do before I further brick my phone.. Thanks all.
Thanks man. Do you think that MOAR is better than LS? And does 4G LTE work? Also, I do have the 4-11 zip file for LS on my sd card already so could i factory and wipe everything and just flash again like I did the first time, get titanium backup, and backup everything old again?Download MOAR rom you should download the newest one (the link to the rom is in the "working roms" thread on this forum) to your sdcard boot into recovery factory reset wipe cache and dalvic cache the go under install zip find MOAR and install it it'll bring up the aroma installer with many options you can choose when installing the rom
Also if you installed ls deathly kernel and your running tw it's going to boot loop because you installed a kernel built for stock android not tw
If you don't want a new rom you can search
Dkp TouchWiz 4.1 kernel and download and install that and the rom should boot just be careful and read everything before you flash anything. I would recommend that you just install MOAR rom though bud
I'm actually really confused on what I should do right now. I would like to be able to keep my apps and all the data i have right now since I haven't backed up since before I flashed the first time..
+100 Fixed lost no data! Maybe would be good for other people to know just incase!WAIT WAIT WAIT
I think I misread the first post before it bootlooped were you on tw or liquid smooth because if your on liquid smooth which I think your saying you were and then you flashed a kernel and it bootlooped you if that's the case
Then download this Getting dkp-aosp44-20140405.zip
And flash it and it'll fix the bootloop
Sorry about that I gave you the wrong directions I was thinking you were saying you just rooted your s3 then download a LS kernel and flashed it and got bootlooped sorry
Good you have it fixed and you could post that the kernel made you bootloop in the working roms thread so everyone would know but I had a bad experience with the ls kernels so I know from experience some versions don't boot and some version only boot the rom on liquid smooth so I leave them alone lol I've got bootlooped plenty of times trying to get that kernel to run on other asop roms
Flash this to get data http://androidforums.com/boost-mobi...universal-boost-apn-fix-d2lte-builds-mod.html
If that doesn't work you'll have to make a backup of your current rom then flash a tw rom and do a prl update and a profile update then go back to your original rom and flash that zip to get data and 4g
I have data alreadyand yeah LS kernels are scary hahaha. Thanks a ton again! Will do my best to find that kernel I flashed. Wanted to delete it asap lol
