Root [Boost Mobile] Cyanogenmod?
Endofear
Hi, so I just got a Samsung Galaxy S3 from boost mobile and I was wondering if I could flash Cyanogenmod onto it after rooting? I also heard that in order to have CM on this specific phone, you need to have an LTE and MMS APN fix. So could I be linked to these specific fixes for the Boost Mobile variant if there are any?
Thanks, Endo
Hey there. Did you check out the posts right at the top of the thread? I think you will find every think you need there.
Cyanogenmod is flashable and you do need and apn fix as well.
It's all there for you, check it out!
Like Smith said. Everything you need is right here in this section. All you need to do is look for it. It is very easy to locate.
One bit of advice I have before you start with CM11, Carbon, Liquidsmooth, or any of the new AOSP ROMS is for you to flash Philz recovery if you are not already running it. Some of these ROMs will not flash if you are running TWRP or the regular CWM recoveries. There is a thread in this section for Philz recovery. I highly recommend that you flash it. It's very easy. All you need to do is put it on your SD card, flash it, reboot back into recovery and you'll be running Philz. :D:thumbup:
