galarue
Hi all - I have been cruising on Tribute for quite some time now and had some issues so I wanted to swap to Wicked. I downloaded and tried to flash but got the wonderful status 7 error, previously I have known this to be because of either asserts in the rom (which there are none) or because I don't have the latest recovery.
I upgraded to the latest philz touch and then when I select apply from SD card, nothing shows up. No directories, no files, nothing and I can't even return to the previous menu. I tried the newest versions of TWRP and CWM as well and they have the exact same issues.
I flashed back to older versions and they can see my internal and external SD card just fine, but I will get the errors while trying to flash anything. I ended up not being able to properly restore my backup either, so I tried flashing over the ND8 update once again to see if that would allow it to happen, nada. Currently I'm on CWM 6.0.3.1 and sitting on stock, unrooted because of all of this so I'm a bit concerned obviously and am certain the key is getting the new recoveries to read my storage. I'm out of ideas now so any advice is appreciated!
