Root [Boost Mobile] Samsung Galaxy s3 Boost Sph-l710t need help please
so i flashed a rom now my modle number says Sph-l710 not Sph-l710t baseband says unknown i dont have any serivce at all i tryed to flash in odin the stock restore maybe i have the wrong one im not sure i just want to get my phone back unrooted and exactly how i bought it and working service please :[
No need to make 3 threads with the same question. There is no Odin TAR for that model S3 yet. What exactly did you flash?
i didnt mean to make 3 my internet laged n i clicked post 2 menny times i guess sorry.. i have flashed alot of things trying to fix this i have flashed all this
wicked x
wifi fix
universtal apn fix for boost
peoples rom
sphl710t modom
slimkat rom
s3 ndc modom
mk5 stock deodexed
md7 stock
all zips all the odin i try to flash dose not work
no i have tried to use odin the only things i have flashed with odin was root and and recovery but it hasent let me flash anything elce it alwase fails. and how would i restore a nandroid backup i have never done that? sorry thanks for the help!
Make a directory on your sdcard in clockworkmod/backup directory. Let's call it stock. So it should look something like clockworkmod/backup/stock. Then copy that backup you downloaded into the folder. Reboot into Philz recovery, select backup and restore, then select restore from sdcard1, then select the backup you want to restore, in this case it will be called stock.
