Root [Boost Mobile] Stock kernel
HiiiPowers
I'm in need of our stock kernel anyone please anyone that could help you are appreciated
I believe it's the stock boost kernel and it's flashable so here you go let me know if not
http://db.tt/QAqxfw7W I got the stock kernel by using flashify and making a backup so if you can't flash it normally download flashify and restore the kernel like that :-)
In also found the camera issue its a kernel issue along with the 3g and 4g but I don't k how to fix it at all :-( :-\ we also need an asop kernal and a touchwiz oc kernel that works ktooonz kernel works and the camera works on it so I figured the camera must be in the kernel but 4g doesn't work only 3g when set to CDMA
And of works also so its probably a simple file missing that stock has to fix the kernel
