Bought a Huawei p10 in Thailand and the charger is different than Europe
Alon2904
Hi guys. I just bought Huawei p10 in Thailand and I got this "super charger" with different pins from Europe.
My questions is
1.if i will connect to the charger some adapter that only change the connection and not the voltage is this will be OK?
2. If I will connect the phone to another charger, of course it will not super charge but it will be OK for the phone battery?
I'm adding the photos of the super charger and my normal charger
E0DpB
As both of your chargers meet the standard
I/P and O/P voltage and current requirements, you can use either of your options :).
Yes, there is some difference in both chargers, one has different Input/output voltage and the second one has different. You need to charge your android smartphone from the original charger so it will keep your battery safe.
