Baptiste30650
Hi ,
After trying to install official update from TWRP over a rooted stock rom my device wont start. :crying:
TWRP recorvery, Stock recovery and FastBoot mode are inaccessible ...
The bootloader is already unlocked.
When i try to flash the stock Rom with SP Flash Tool i get this error :
Mediatek Vcom driver and vernee pro v2 latest driver are installed too.
I've found only two different link of the Rom, i've tried to flash both without success.
I've tried to flash only TWRP recovery : same error
I've also tried to flash the rom without the preloader ticked : same issue
I've tried with the Firmware Upgrade selected instead of download in SPFT : same issue
Here is the Scatter File of the Stock Rom downloaded from getdroidtips's website V2_Pro_20180620.rar Same Rom on any other website Needrom, Cyanogenmod ....
Here is the Scatter file found in the rom downloaded from Vernee's official website V2_Pro_20180620_user-full_k63v2_64_bsp-ota-1529505491.zip Can't flash it : invalid scatter file
Here are the V2_Pro_20180620_user-full_k63v2_64_bsp-ota-1529505491.zip files : Official Vernee Website
Here are the V2_Pro_20180620.rar files :
I don't understand why in the getdroitips V2_Pro_20180620.rar Rom the preloader filename is preloader_k63v2_64_bsp.bin because in the stock Rom given by Vernee's website V2_Pro_20180620_user-full_k63v2_64_bsp-ota-1529505491.zip the preloader filename is preloader.img .
I've had tried to swap preloader files and modify the MT6763_Android_scatter.txt according to the preloader file type with no success.
I've also verified if the adress was same in the two scatter files ...
Tomorow i will retry with an another computer Maybe my problem is due to conflict between drivers ...
Thanks you in advance for your precious help !
I'm so sad my device is new :crying:
I've tried to flash it with many versions of SPFT(0xC0030004) ERROR : STATUS_PRELOADER_INVALID
The Preloader file format is invalid!!
HTML:
# General Setting
- general: MTK_PLATFORM_CFG
info:
- config_version: V1.1.2
platform: MT6763
project: k63v2_64_bsp
storage: EMMC
boot_channel: MSDC_0
block_size: 0x20000
# Layout Setting
- partition_index: SYS0
partition_name: preloader
file_name: preloader_k63v2_64_bsp.bin
is_download: true
type: SV5_BL_BIN
linear_start_addr: 0x0
physical_start_addr: 0x0
partition_size: 0x40000
region: EMMC_BOOT1_BOOT2
storage: HW_STORAGE_EMMC
boundary_check: true
is_reserved: false
operation_type: BOOTLOADERS
is_upgradable: true
empty_boot_needed: false
reserve: 0x00
- partition_index: SYS1
partition_name: pgpt
file_name: NONE
is_download: false
type: NORMAL_ROM
partition_size: 0x8000
region: EMMC_USER
is_reserved: false
operation_type: INVISIBLE
is_upgradable: false
reserve: 0x00
- partition_index: SYS2
partition_name: boot_para
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x8000
physical_start_addr: 0x8000
partition_size: 0x100000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS3
partition_name: recovery
file_name: recovery.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x108000
physical_start_addr: 0x108000
partition_size: 0x2000000
region: EMMC_USER
is_reserved: false
operation_type: UPDATE
is_upgradable: true
reserve: 0x00
- partition_index: SYS4
partition_name: para
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x2108000
physical_start_addr: 0x2108000
partition_size: 0x80000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS5
partition_name: expdb
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x2188000
physical_start_addr: 0x2188000
partition_size: 0x1400000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS6
partition_name: frp
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x3588000
physical_start_addr: 0x3588000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS7
partition_name: nvcfg
file_name: NONE
is_download: false
type: EXT4_IMG
linear_start_addr: 0x3688000
physical_start_addr: 0x3688000
region: EMMC_USER
is_reserved: false
operation_type: PROTECTED
reserve: 0x00
- partition_index: SYS8
partition_name: nvdata
file_name: NONE
is_download: false
type: EXT4_IMG
linear_start_addr: 0x5688000
physical_start_addr: 0x5688000
partition_size: 0x4000000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS9
partition_name: metadata
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x9688000
physical_start_addr: 0x9688000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS10
partition_name: protect1
file_name: NONE
is_download: false
type: EXT4_IMG
linear_start_addr: 0xb688000
physical_start_addr: 0xb688000
partition_size: 0x800000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS11
partition_name: protect2
file_name: NONE
is_download: false
type: EXT4_IMG
linear_start_addr: 0xbe88000
physical_start_addr: 0xbe88000
partition_size: 0x978000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS12
partition_name: seccfg
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xc800000
physical_start_addr: 0xc800000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS13
partition_name: sec1
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xd000000
physical_start_addr: 0xd000000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS14
partition_name: proinfo
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xd200000
physical_start_addr: 0xd200000
partition_size: 0x300000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS15
partition_name: md1img
file_name: md1img.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0xd500000
physical_start_addr: 0xd500000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS16
partition_name: md1dsp
file_name: md1dsp.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x11500000
physical_start_addr: 0x11500000
partition_size: 0x1000000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS17
partition_name: spmfw
file_name: spmfw.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x12500000
physical_start_addr: 0x12500000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS18
partition_name: sspm_1
file_name: sspm.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x12600000
physical_start_addr: 0x12600000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS19
partition_name: sspm_2
file_name: sspm.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x12700000
physical_start_addr: 0x12700000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS20
partition_name: gz1
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x12800000
physical_start_addr: 0x12800000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS21
partition_name: gz2
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x13800000
physical_start_addr: 0x13800000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS22
partition_name: nvram
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x14800000
physical_start_addr: 0x14800000
region: EMMC_USER
is_reserved: false
operation_type: BINREGION
reserve: 0x00
- partition_index: SYS23
partition_name: lk
file_name: lk.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x18800000
physical_start_addr: 0x18800000
region: EMMC_USER
is_reserved: false
is_upgradable: true
empty_boot_needed: true
reserve: 0x00
- partition_index: SYS24
partition_name: lk2
file_name: lk.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x18900000
physical_start_addr: 0x18900000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS25
file_name: boot.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x18a00000
physical_start_addr: 0x18a00000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS26
partition_name: logo
file_name: logo.bin
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x1aa00000
physical_start_addr: 0x1aa00000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS27
partition_name: odmdtbo
file_name: odmdtbo.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x1b200000
physical_start_addr: 0x1b200000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS28
partition_name: tee1
file_name: tee.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x1c200000
physical_start_addr: 0x1c200000
partition_size: 0x500000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS29
partition_name: tee2
file_name: tee.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x1c700000
physical_start_addr: 0x1c700000
partition_size: 0x900000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS30
partition_name: vendor
file_name: vendor.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0x1d000000
physical_start_addr: 0x1d000000
partition_size: 0x29000000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS31
partition_name: system
file_name: system.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0x46000000
physical_start_addr: 0x46000000
partition_size: 0xF4800000
region: EMMC_USER
is_reserved: false
is_upgradable: true
reserve: 0x00
- partition_index: SYS32
partition_name: cache
file_name: cache.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0x13A800000
physical_start_addr: 0x13A800000
partition_size: 0x1b000000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS33
partition_name: userdata
file_name: userdata.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0x155800000
physical_start_addr: 0x155800000
partition_size: 0xc0000000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS34
partition_name: sdrpmb
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xFFFF0140
physical_start_addr: 0xFFFF0140
partition_size: 0x1800000
region: EMMC_USER
boundary_check: false
is_reserved: true
operation_type: RESERVED
reserve: 0x00
- partition_index: SYS35
partition_name: flashinfo
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xFFFF0080
physical_start_addr: 0xFFFF0080
region: EMMC_USER
is_reserved: true
reserve: 0x00
- partition_index: SYS36
partition_name: sgpt
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xFFFF0000
physical_start_addr: 0xFFFF0000
partition_size: 0x4200
region: EMMC_USER
is_reserved: true
reserve: 0x00
HTML:
preloader 0x0
pgpt 0x0
boot_para 0x8000
recovery 0x108000
para 0x2108000
expdb 0x2188000
frp 0x3588000
nvcfg 0x3688000
nvdata 0x5688000
metadata 0x9688000
protect1 0xb688000
protect2 0xbe88000
seccfg 0xc800000
sec1 0xd000000
proinfo 0xd200000
md1img 0xd500000
md1dsp 0x11500000
spmfw 0x12500000
sspm_1 0x12600000
sspm_2 0x12700000
gz1 0x12800000
gz2 0x13800000
nvram 0x14800000
lk 0x18800000
lk2 0x18900000
boot 0x18a00000
logo 0x1aa00000
odmdtbo 0x1b200000
tee1 0x1c200000
tee2 0x1c700000
vendor 0x1d000000
system 0x46000000
cache 0x13a800000
userdata 0x155800000
sdrpmb 0xFFFF0140
flashinfo 0xFFFF0080
sgpt 0xFFFF0000
HTML:
| boot.img
| file_contexts.bin
| h.txt
| lk.img
| md1dsp.img
| md1img.img
| odmdtbo.img
| preloader.img
| scatter.txt
| spmfw.img
| sspm.img
| system.new.dat.br
| system.patch.dat
| system.transfer.list
| tee.img
| type.txt
| vendor.new.dat.br
| vendor.patch.dat
| vendor.transfer.list
\---META-INF
\---com
+---android
| metadata
| otacert
\---google
\---android
update-binary
updater-script
HTML:
| boot.img
| cache.img
| h.txt
| lk.img
| logo.bin
| md1arm7.img
| md1dsp.img
| md1img.img
| md3img.img
| odmdtbo.img
| recovery.img
| secro.img
| spmfw.img
| sspm.img
| system.img
| tee.img
| userdata.img
| vendor.img
\---calibration
| APDB_MT6763_S01_alps-trunk-o1.bsp_W17.50
\---s600_tk_md_basic-lwctg_r2_6763-6m_gsm4p_w1_2_4_5_8_fdd1_2_3_4_5_7_8_12_17_19_20_tds34_39_tdd34_38_39_40_41_c2kbc0bc1_cotsx_airohapa_tiaoxie
