I soft brick my phone it turns on but is stuck on the caution bootloader unlocked screen plz help what to fix it if possible
yeah actually ran recovery through twrp but now it says there is no os installed
for some reason now i can't even access my recovery so not quite sure what to do
i managed to get into recovery think the battery was to low. how do i Push a flashable zip to the SD card/ internal storage and then install it with TWRP.
I don't have your phone but Moto also uses xml files. That link above to the download files is to be used with rsdlite. Your phone will be back to complete stock after but at least it will be running.
You can also try this link for another link to rsd files. http://forum.xda-developers.com/showthread.php?t=1858959
tried that still getting the same error message I don't know what the deal is
