Brightness Hotkey? for sunlight/invisible screen
jlm86
What might be the work around for a key to hit and enable Max Brightness?
I find myself at times outside, and damn cannot see the ***** screen, so i cannot even dive into the home screen to see to hit max brightness?
Ideally: Would like a 2-Click Home Button to enable Max Brightness..
thanks
And if you find the auto brightness too dim (as many do), the app Lux Auto Brightness works great--you can set the brightness vs. ambient light level to whatever you want.
Setting your brightness to auto should put it to max when you're in bright sunlight.
I dont like autobrightness. It doesn't go to Max, so its still not always bright enough. Plus I dont like the constant use of sensors to set the appropriate brightness. I actually find it detrimental to battery life compared to manually setting it.
That said, it leaves you with the possible setting too low when you're at lock screen.
Enter "Tasker" :)
