Hello,
I`ve just purchased a Android TV box to link with my WD Cloud so i can use XBMC as my player for streaming.
I`ve got a real bad problem that is getting to me know and have no idea as to what to do.
All my devices in the house are hardwired nothing is over Wifi only phones.
When playing video either from my WD Cloud, sites, you tube, live Sports the picture will not stop buffering.
I have read so many forums, you tube videos and nothing has worked.
Ive installed FUSION and had access to the maintenance tool and re set the cache to Zero still no joy!.
When ever I stream a film via my WD Cloud it will buffer for 20seconds then comes up "Cache Full before finished" movie plays for 3 minutes then i have stop, start, stop, start buffering Ahhhhhhh!!
Just wondering if you can connected a USB stick and get the cache transfering to that rather than the android box?
Or is there any way you can get the buffering to buff 50% of the file before starting toplay?
Has anyone got an ideas to resolve this as its a huge problem and if there isnt a work around then I`ll be sending it back.
Kind Rgds
Coops
Kind Rgds
Coops
