Zorphan
So im up to step3 of Firebase setup.. paste code onto Project-level build.gradle (/build.gradle).. but the file doesnt have Dependancies or Repositorie on the file..
Here is a copy of my build.Gradle Project file..
...so where do i paste the file from Firebase? everywhere i paste it, it wont syn. Or have i not set up the program correctly? im using Kotlin
Just so you talented people know .. ive just started Progaming.. today. So if you could explain what im doing wrong and explain your code it would help me learn from my mistakes.. having dyslexia is tough enough lol. Im trying to build a communication app for my son who has mental helath issues.
Thanks for any help
Code:
// Top-level build file where you can add configuration options common to all sub-projects/modules.
plugins {
id 'com.android.application' version '7.1.0' apply false
id 'com.android.library' version '7.1.0' apply false
id 'org.jetbrains.kotlin.android' version '1.6.10' apply false
task clean(type: Delete) {
delete rootProject.buildDir
Thanks for any help
