build number
  • Start date Start date
A
Android Question
Guest
what is mean by build number, and what is the use of it
Hello and welcome to Android Forums. Hopefully I can help you with your problem.
The build number can refer to a number of things. Here in the forums it usually means the build of the bootloader you are running. It let's you know what mods or ROMs can be flashed on your device.
Example.. Some mods and ROMs that are made for a certain build number can brick (ruin) a device if it is flashed on a device that has a different build number that it is made for.
If you have any other questions regarding your device, I invite you to join Android Forums. We have many sections for specific devices which contain a wealth of information.
