Root Build.prop tweaks ?
Yup, i even made a tweak. Screen size can only go down to 120 but anything should work if change in the Build.Prop
Anything over 120 makes the screen look cluttered.
well a little lost do any of you know of a tweak for scrolling responsiveness and performance . i saw on the triumph forum that they have GPU and CPU rendering that increase perfomance dramatically .
Well we are out of luck there. The M835 doesn't have a dedicated GPU, everything is handled by the CPU. This is why the phone seems slower than other same clocked tablets and phones. But if you can find how to implement disabling dithering the performance would be increased as well as improved menu elements could help the speed.
On top of that the CPU is really shifty so it can't really handle anything pretty much.
so i should throw out these perfrmance tweaks :/ .. well what about scrolling .. the scrolling tweak ?
I've. gotten my M835 down to 110 on the size and I cant find any performance tweaks except for the v6 script that u can find on xda.
The v6 script doesn't really do too much for the m835 it does make it faster, not by much however.
