CMake Error at C:/Users/windows/AppData/Local/Android/Sdk/cmake/share/cmake-3.11/Modules/CMakeDetermineSystem.cmake:100 (message):
Could not find toolchain file:
C:\Users\windows\AppData\Local\Android\Sdk\cmake\android.toolchain.cmake
Call Stack (most recent call first):
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMake Error: CMake was unable to find a build program corresponding to "Ninja". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
Configuration failed.
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
CMakeLists.txt
