Hello everybody,
I am new in Android application.
I am facing a problem when i am going to build Android project using Ant tool.
I have made a build.xml file and it is giving that BUILD SUCCESSFUL.
But the AndroidManifest.xml file is not adding with the .apk file.
For that when i am going to install the .apk file it is giving the message "AndroidManifest.xml file not found".
I am giving the Build.xml file below.
<?xml version="1.0" ?>
<project name="HelloWorldCommandLine" default="package" basedir=".">
<property name="sdk-folder" value="C:/android-sdk-windows-2" />
<property name="android-tools" value="${sdk-folder}/tools" />
<property name="android-framework" value="${android-tools}/lib/framework.aidl"/>
<!-- The intermediates directory -->
<!-- Eclipse uses "bin" for its own output, so we do the same. -->
<!-- Use full path for output dir - FIX - BLOCK START -->
<property name="outdir" value="${basedir}/bin" />
<!--<property name="outdir" value="bin" /> -->
<!-- No user servicable parts below. -->
<!-- Input directories -->
<property name="resource-dir" value="res" />
<property name="asset-dir" value="assets" />
<property name="srcdir" value="src" />
<!-- Output directories -->
<property name="outdir-classes" value="${outdir}/classes" />
<!-- Create R.java in the source directory -->
<property name="outdir-r" value="src" />
<!-- Intermediate files -->
<property name="dex-file" value="classes.dex" />
<property name="intermediate-dex" value="${outdir}/${dex-file}" />
<!-- The final package file to generate -->
<property name="out-package" value="${outdir}/${ant.project.name}.apk"/>
<!-- Tools -->
<property name="aapt" value="C:/android-sdk-windows-2/platforms/android-2.0/tools/aapt.exe" />
<property name="aidl" value="C:/android-sdk-windows-2/platforms/android-2.0/tools/aidl.exe" />
<condition property="dxbat" value="C:/android-sdk-windows-2/platforms/android-2.0/tools/dx.bat"
else="C:/android-sdk-windows-2/platforms/android-2.0/tools/dx" >
<os family="windows"/>
</condition>
<!--<property name="dx" value="${android-tools}/dx" />-->
<property name="adb" value="${android-tools}/adb" />
<property name="android-jar" value="C:/android-sdk-windows-2/platforms/android-2.0/android.jar" />
<property name="zip" value="zip" />
<!-- Rules -->
<!-- Create the output directories if they don't exist yet. -->
<target name="dirs">
<mkdir dir="${outdir}" />
<mkdir dir="${outdir-classes}" />
</target>
<!-- Compile this project's .java files into .class files. -->
<target name="compile" depends="dirs, resource-src, aidl">
<javac encoding="ascii" target="1.5" debug="true" extdirs=""
srcdir="."
destdir="${outdir-classes}"
bootclasspath="${android-jar}" />
</target>
<!-- Generate the R.java file for this project's resources. -->
<target name="resource-src" depends="dirs">
<echo>Generating R.java...</echo>
<exec executable="${aapt}" failonerror="true">
<arg value="package" />
<arg value="-m" />
<arg value="-J" />
<arg value="${outdir-r}" />
<arg value="-M" />
<arg value="AndroidManifest.xml" />
<arg value="-S" />
<arg value="${resource-dir}" />
<arg value="-I" />
<arg value="${android-jar}" />
</exec>
</target>
<!-- Generate java classes from .aidl files. -->
<target name="aidl" depends="dirs">
<apply executable="${aidl}" failonerror="true">
<arg value="-p${android-framework}" />
<arg value="-I${srcdir}" />
<fileset dir="${srcdir}">
<include name="**/*.aidl"/>
</fileset>
</apply>
</target>
<!-- Convert this project's .class files into .dex files. -->
<target name="dex" depends="compile">
<exec executable="${dxbat}">
<!--failonerror="true"> -->
<!--<arg value="-JXmx384M" />-->
<arg value="--dex" />
<arg value="--output=${basedir}/${intermediate-dex}" />
<arg value="--locals=full" />
<arg value="--positions=lines" />
<arg path="${basedir}/${outdir-classes}" />
</exec>
</target>
<!-- Put the project's resources into the output package file. -->
<target name="package-res-and-assets">
<echo>Packaging resources and assets...</echo>
<exec executable="${aapt}">
<!-- failonerror="true"> -->
<arg value="-f" />
<arg value="-c" />
<arg value="-M" />
<arg value="-S" />
<arg value="-A" />
<arg value="${asset-dir}" />
<arg value="-I" />
<arg value="${out-package}" />
</exec>
</target>
<!-- Same as package-res-and-assets, but without "-A ${asset-dir}" -->
<target name="package-res-no-assets">
<echo>Packaging resources...</echo>
<arg value="-f" />
<arg value="-c" />
<arg value="-M" />
<arg value="-S" />
<!-- No assets directory -->
<arg value="-I" />
</exec>
</target>
<!-- Invoke the proper target depending on whether or not
an assets directory is present. -->
<!-- TODO: find a nicer way to include the "-A ${asset-dir}" argument
only when the assets dir exists. -->
<target name="package-res">
<available file="${asset-dir}" type="dir" property="res-target" value="and-assets" />
<property name="res-target" value="no-assets" />
<antcall target="package-res-${res-target}" />
</target>
<!-- Put the project's .class files into the output package file. -->
<target name="package-java" depends="compile, package-res">
<echo>Packaging java...</echo>
<jar destfile="${out-package}"
basedir="${outdir-classes}"
update="true" />
</target>
<!-- Put the project's .dex files into the output package file.
Use the zip command, available on most unix/Linux/MacOS systems,
to create the new package (Ant 1.7 has an internal zip command,
however Ant 1.6.5 lacks it and is still widely installed.)
<target name="package-dex" depends="dex, package-res">
<echo>Packaging dex...</echo>
<exec executable="${zip}" failonerror="true">
<arg value="-qj" />
<arg value="${intermediate-dex}" />
</exec>
</target>
<!-- Create the package file for this project from the sources. -->
<target name="package" depends="package-dex" />
<!-- Create the package and install package on the default emulator -->
<target name="install" depends="package">
<echo>Sending package to default emulator...</echo>
<exec executable="${adb}" failonerror="true">
<arg value="install" />
</exec>
</target>
</project>
<!-- Tools -->
</condition>
<!-- Rules -->
</target>
srcdir="."
</target>
<arg value="-m" />
<arg value="-J" />
<arg value="-M" />
<arg value="-S" />
<arg value="-I" />
</exec>
</target>
</fileset>
</apply>
</target>
</exec>
</target>
<arg value="-f" />
<arg value="-c" />
<arg value="-M" />
<arg value="-S" />
<arg value="-A" />
<arg value="-I" />
</exec>
</target>
<arg value="-f" />
<arg value="-c" />
<arg value="-M" />
<arg value="-S" />
<arg value="-I" />
</exec>
</target>
</target>
update="true" />
</target>
<arg value="-qj" />
</exec>
</target>
</exec>
</target>
</project>
