burned sd card
  • Start date Start date
A
Android Question
Guest
Yesterday my phone stated that my sd card had been removed. It had not. All of the apps on the card came up "not installed. " I moved the important apps to phone storage. Is it possible to reboot my card?
Welcome to Android Forums!
I might suggest Storage Analyzer, free in Play.
SD cards DO go bad. I had one fry on me in my last phone. So you might consider backing your important data like photos to a PC from time to time. Good luck and I hope this helps.
It's great to have you here :)
