I am working on an app, and i have a strange problem. In my main class (Event) it extends  tabactivity, because it needs to initialize the tabs. So in my 2nd class (buttonManager) i have the code for when the buttons are pressed that they will switch the view to the appropriate layout. The buttonManager still has the blurb of code:
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.input);
i tried removing the @Override, it doesn't work, and i tried moving the code to Event, but it doesn't work, because it extends tabactivity, not activity. I am wondering if it is a problem that my buttons aren't in the main one, or if there is any way for my main class to extend both activity and tab activity.
Here is the code for buttonmanager, the class that handles the buttons if you are interested to see how it looks:
I know that all of the cases aren't coded in yet, but the one that is doesn't work, so i decided not to put anything else in yet until it's fixed.
The chrono class just is the set view code.
			@Override
		Code:
	package com.dev.ir.im;
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
public class buttonManager extends Activity implements OnClickListener {
    @Override
          // Clicklistener setup
          View stretcher = findViewById(R.id.stretchbutton);
          stretcher.setOnClickListener(this);
          View yoga = findViewById(R.id.yogabutton);
          yoga.setOnClickListener(this);
          View arms = findViewById(R.id.armbutton);
          arms.setOnClickListener(this);
          View legs = findViewById(R.id.legworkouts);
          legs.setOnClickListener(this);
          View core = findViewById(R.id.corebutton);
          core.setOnClickListener(this);
          View other = findViewById(R.id.otherbutton);
          other.setOnClickListener(this);
          View timer = findViewById(R.id.timerbutton);
          timer.setOnClickListener(this);
    public void onClick(View v) {
        switch (v.getId()) {
          case R.id.timerbutton:
             onTimerClick();
             break;
    public void onTimerClick() {
        Intent ti = new Intent(this, chrono.class);
        startActivity(ti);
