Buzz Launcher: how to extract wallpaper files
cdl
Many of you will have heard of Buzz Launcher:
https://play.google.com/store/apps/details?id=com.buzzpia.aqua.launcher&hl=en
What's unique about this launcher is that users can save and share, by uploading them here:
https://www.homepackbuzz.com/homepack/list
Their home screens, ie not just a theme but the entire layout of wallpaper, icons, widgets, etc.
I wanted to share with you what I learnt about how the app stores data on the phone's memory. This is because I couldn't find a way to find the wallpaper files and apply them using another launcher.
The easiest way I found is to download a homepack, apply it, then do a backup (menu -> buzz settings --> backup) which will be stored as a.bbak file in this folder in the phone's internal SD:
buzz_launcher/backup
In fact, it's simply a .zip file. You can change the extension to .zip, and easily extract the wallpaper, which is typically called wallpaper.png
Also, when you download a homepack, the data is typically stored in:
Android/Data/com.buzzpia.aqua.launcher/files/files.zip
but I haven't managed to extract wallpapers from there.
Hope this helps!
