kfisher123
How do I get rid of that annoying lock screen? It's always in the way and I don't always have both hands free.
Trusted places. I'm not sure if it's just an HTC thing though.
If the Patriots lose I'm switching to LG.
Settings>Security>Screen Lock = None
Might vary between phones. I can select "None" and not have to swipe, when turning the screen on it's immediately on the home screen.Even if you disable the screen lock, you still have to swipe before using your phone.
The other options for your lock screen can be greyed out for several reasons:Settings >security >lock screen. I'm unable to select ANYTHING other than password and fingerprint. How do I unlock and access SWIPE only?
The other options for your lock screen can be greyed out for several reasons:Ron64Settings >security >lock screen. I'm unable to select ANYTHING other than password and fingerprint. How do I unlock and access SWIPE only?
Having multiple accounts on the phone
Using encryption
If an app is also using that password
And maybe others
If it's from an app no longer being used but still on the phone you can try clearing the apps cache, then see if None is still greyed out.
Clear an apps cache:
1. Go to Settings -> Apps
2. Tap the app
3. Tap Clear Cache
4. You can also tap Clear Data if you're not using app at all.
