If you are unsure about weather to delete an app or not, just ask hear. Someone will lead you in the right direction.[emoji217]ok guys appreciate the input firstly i am not at all familiar with your knowledge, LGMS631 I rooted it with king root, installed jrummy rom installer and toolbox,twrp ,SU . i tryed to install another SU on jr/rom after the wifi switch on the pull down screen was flashing, i ended up removing it with jr/appmanager .its completely wiped off the device. i did glance on u tube the same LG with flashing on n off off wifi switch,but it was of no use anymore as i had already wiped it. the reason being i mistakenly thought playstore would be packed with custom wifi. its embarassing thats why i left out details...
http://androidcreations.weebly.com/flashable-update-zip.html
Do that and you should be good, as a rule of thumb never uninstall anything that came with the phone without backing it up first, something like Titanium Backup works.
Thx Blu8 i've got the zip ,but i must mention that my LG is not compatable yet with twrp , 5.1.1 android .so what should i do? i appreciate the helphttp://androidcreations.weebly.com/flashable-update-zip.html
i will in the future ,im not at all computor ,back in my day the only phones out of house took coins ha haIf you are unsure about weather to delete an app or not, just ask hear. Someone will lead you in the right direction.[emoji217]
.I dont have the file yet ,you need wifi to download 8( its at only 43%thx B
x i have all that done already its the wrong one for my device twrp emailed me .do you have the ms631?Hmm, if you have the MS631 then TWRP is definitely available for you, I have that same version of the Stylo. To install it you have to turn on developer options (settings>about phone>software info and tap on build number a bunch of times) once you did that and it says "you're now a developer" back out and a new option should be there right above "about phone" named developer options. Tap that and then scroll down to the line that says allow oem unlocking and tick that on. Then use the guide to install TWRP with flashify
ok my new friend ,i haveNothing we can do what you gave us man, all I can say is kdz back to stock but you didn't tell us anything relevant
If you're rooted with kingroot this should work, other than root and what's given in this page you don't need any of those other apps. When you have TWRP installed then you can flash that other thing you downloadedI do have the MS631, I'm also getting the feeling that you're trying to use the jrummy toolbox which just isn't going to work because we don't have a device supported by TWRP. You'd need to get it from here and follow those instructions.
http://androidcreations.weebly.com/lg-g-stylo-twrp.html
Thx your awesum ! got that done,i did the dowload,twrp ,flashify n im type n still phew ha ha . i like the rum toolbox i delete alot of bloat ,but alas king user has that option. thats whay messed me up i thought i ruined the wifi so i wiped it and thought playstore would have all kinds of wifi installs not! im all for learning as much as i can. im on this around the clock i've 60.7k n climbing evra day . i can post stuff for ya ta ma clan no worrysIf you're rooted with kingroot this should work, other than root and what's given in this page you don't need any of those other apps. When you have TWRP installed then you can flash that other thing you downloaded
