Help bypass frp on lg v 10
i bougt a used v10 and i cant get past t google account frp. ive tried everything you tube has and theres always a step in the process that i cant access. can anybody help i cant afford another phone
The post above your has a link to an article with advice on how to bypass it (which has other such links within it), but since any such trick is a security hole Google will work to close them off. So try the things it suggests, but I can't guarantee that they will work for you.
So the best would be to speak to the person you bought it from. The whole point of an anti-theft system is that it has to be hard to bypass. The previous owner should have removed the account from the phone before resetting it, but since they clearly didn't, logging in with that account (which can then be removed and replaced with your own) is by far the simplest, and possibly the only, solution.
If you bought it second-hand from a shop rather than an individual, return it for a refund on the grounds that it's not useable. Consumer protection law should be on your side there.
