Help Calendar Help
I've been getting the "Unfortunately, Calendar has stopped" error.
It happens, well when I use the Calendar lol. I can open it but as soon as I try to do something it closes.
I'm using the Google Calendar, and tried downloading aCalendar but it does the same thing.
This might be the kicker, I removed S Calendar (or is it called S Planner?) from the phone using Titanium Backup... I just can't recall using Google Calendar afterwards or not... How do I download S Planner/Calendar again? Or is the problem something else?
I went into the app manager and cleared the Google Calendar multiple times and have tried uninstalling/re-install.
Also, Google Calendar sync isn't working, which Im guessing is tied to this.
I ended up just reflashing the stock ICS rom (since I already had it saved on my laptop) then upgrade with KIES to jellybean. I restored app data with titanium and the Calendar still doesnt work yet S Planner does
