Help Calendar not syncing correctly past September.
I cannot get my calendar to sync properly. I have tried clearing data in calendar and calendar storage. I have resynced numerous times. Any suggestions? Thanks!
I assume you are only using Google Calendar for your sync? (I use sync between my Outlook and Google Calendar.)
I would first try reviewing my settings on both the website and the phone. Make sure that the settings show sync: Go to menu>settings>accounts and sync>Google and make sure the sync box is still checked.
(I just noticed that my Google account states, "Sync is currently experiencing problems. It will be back shortly." This may be the issue?)
Thank you for responding. Where did you see that on your google account (the sync error message)?
menu=>settings=>accounts and sync=>Google
It was still there when I just checked, and I manually synced and the Google sync finally synced. You might try it also.
