Call confirm help
A lockscreen. Or a flip case which covers the screen.
There are apps that can be used to PIN protect certain apps. I've never used one but I guess if you did that for your phone app it would work.
Or remove the icon that you are accidentally hitting from wherever it is (dock or lockscreen - I know nothing about your setup). If you had to open a folder or bring up the app drawer to access it that would make it less likely).
I have a lock screen after 30secons or so. Im disabled and am a bit 'clumsy' i suppose and can even manage to hang up a call and then touch to call again!! Thought if i had to reconfirm it, it might stop it.
As Hadron suggests, removing the icon off your home screen would work the best.
No accidental calls...
I think I have just worked out it happens mostly when a call finishes and the dialler Page is still on the screen I am accidentally touching it again straight away. As i say, im disabled and all fingers and thumbs.
Hmm, that will be tricky to stop as the app is already open. I doubt it's possible without modifying the dialer app itself (which isn't a realistic option).
