Help call defer question !!!!!!!!!!!!
revs1227
Member
ok i know u can defer calls with a text when u reject them but i was wondering if you can d this all the time i.e defer all calls with a text while your away from your phone i sometimes get swamped with calls from work and i just cant take it n turn my phone off ..right now i am using the feature that allows you to just block your entire phone book
yes, but I think forwarding only works for a number. I think he's looking for a way to defer all to a text like the individual "defer" button does. That's kind of interesting, perhaps theirs a third party app to do it?
you are correct, however, you can forward the calls to your voicemail number. in fact the preset forward number is the voicemail number.
I'm telling you, you can forward calls directly to your voicemail box number...but if you'd rather have a app to do a built in function then by all means try one. I just don't see the point. Since you don't want to use call forwarding you can use "extreme call blocker droid" and schedule when to block calls.
