Then you'll probably have to contact Virgin Mobile to find the method to increase your ring duration. If contacting customer service sends a chill down your spine, you might try a few other things first like rebooting your phone. If that doesn't fix it, you might also try putting your sim in another phone and calling that to see if it has the same problem. If it does, then it's definitely VM handing the calls.
I take it that fixed it?Many thanks. i should have tried re-starting the phone before I posted ...
My phone has suddenly started forwarding calls to voicemail after only 1 ring. I can't find a setting to change the delay.
I am running Nougat on a Samsung J5; my carrier is Virgin.
My phone is not rooted (please don't suggest that I root it).
. Just ignore me....I'm used to it
