Criinx
I have a String which is getting Data external from a MYSQL database into a TextView which shows me then the result.
Is it possible to show this Data string into a CalendarView? Or should I create Events...
In example getting string from SHIFT:
I need to put this SHIFT data into a CalendarView but every SHIFT is in a another day.
Code:
new getData().execute("");
private class getData extends AsyncTask<String, Void, String> {
String name;
@Override
protected String doInBackground(String... params) {
result = "";
ipStr = null;
try {
HttpClient httpClient = new DefaultHttpClient();
HttpPost httpPost = new HttpPost("link to php......");
HttpResponse httpResponse = httpClient.execute(httpPost);
HttpEntity entity = httpResponse.getEntity();
ipStr = entity.getContent();
}catch (Exception e){
Log.e("Log_tag", "Error bei der Verbindung" + e.toString());
try {
BufferedReader reader = new BufferedReader(new InputStreamReader(ipStr, "iso-8859-1"), 8);
StringBuilder sb = new StringBuilder();
String line = null;
while ((line = reader.readLine()) != null){
sb.append(line + "\n");
ipStr.close();
result = sb.toString();
Log.e("log_tag", "Error bei der Konvertierung, daten wurden nicht erfolgreich gefunden" + e.toString());
try {
JSONArray jArray = new JSONArray(result);
for (int i = 0; i < jArray.length(); i++){
JSONObject json = jArray.getJSONObject(i);
Data = Data + "" + json.getString("schift");
Data = Data + "" + json.getString("firstname");
DataShortcut = DataShortcut + "" + json.getString("shortcut");
Log.e("log_tag", "Error Analyserien der Dateien" + e.toString());
return "Executed";
