Sometime when I dial a number, instead of being clear, the ringtone sounds like it's being said by a Dalek. The person talking on the other end also sounds the like a Dalek and is almost unintelligible. Often I have to recall the number 4-5 times and then suddenly I get a clear line. Sometimes the call starts with the dalek-like sound and then suddenly clears. It seems odd that it's not a persistent problem, which would clearly point to the phone. It if was common then I would have seen lots of reports of this and I can't say I have seen any. I guess this would imply the phone is probably at fault, but the intermittent nature makes me feel that the mobile operator (3 UK) will probably test the phone and say it's fine. I guess I could record the phone calls and play it back to them. Any other suggestions?
regards
Mark
regards
Mark
