Camera Adjustments
djlen
To put it mildly.....the pictures my camera takes are terrible. When I upload them to my computer they are grainy and very small. How do I adjust the pixels etc. in order to get quality shots?
Regards,
Len
yes, press camera button, till camera comes on
menu/settings/picture resolution select widescreen or large
and make sure flash is set to auto
mine has always taken good photos
OK, thank you for the reply. Under settings,
Widescreen was not checked so I checked it. There was no option for "large" so I guess by checking widescreen that should do it, correct?
Regards,
Len
yes, that is best resolution, there should have been 4 or 5 options to scroll through
with widescreen at top
