Camera hardware..
Milo Willamson
Extreme Android User
Becomes too hot, like accidently swipe it on the hardware and it becomes suddenly warm..
Becareful though, I do not that side of the are much while holding on my cell too. It felt very odd and just out of the blue though.
When in auto burst with touching everywhere to snapshot, noticed half the time it will not respond, and when you do photograph I think around
300 photos, tends to slow down after that, so yeah if you are going to photograph something like a bird's flight pattern, just be careful on what you photograph last, dump them into the comp first, then reset, again it is alright photographing a still one time over the other too. Just be aware on the camera's default app, use a different type of camera, also tends to freeze up over time.
Acutally it was just another useless app in the background, after doing some sample snapshots yesterday, it does not get hot, so I am wondering about when to turn off the phone even sooner ? :) I will attempt to remember that.
