sargan
Member
I have found an issue with camera on my S7… maybe its settings, but could be a bug, and the issues may be related.
SM-G930F
running 6.0.1
Firstly … if I set it to save as RAW file (my preference) … I can do this OK, via camera>mode/Pro>settings
However, if you exit camera … when you next go into camera it has defaulted to standard mode & jpeg
Can it be set it to ‘lock to RAW mode’ (and ideally PRO mode) even if via a different shortcut.
Secondly .. in camera>settings I have Storage Location set as SD card.
However any pictures taken in RAW mode are saved in device storage ….. this is a particular issue as RAW files are larger and I would much prefer the SD card space for this.
SM-G930F
running 6.0.1
