Camera question for those running Jelly bean
Hi all. Just a curiosity question here for those running Jelly Bean on your s3 through a ROM or whatnot.
Concerning the camera, one of the cool features about Jelly Bean is that pictures slide out to the right when you take them and then instead of going to your gallery to see them, you can just swipe to the right and start looking at your pics. I was wondering if this holds true on the S3 or if the touch wiz software "overrides" it? Thanks for your help! I really hope this feature is included.
Not sure what you mean when you say "you can just swipe to the right and start looking at your pics"
I'm running JB and see no difference to how the camera app works. When you take a pic it appears in a small window to the right of the view window. You can click on that to view\edit the image.
I can't get that feature to work, when I swipe on the camera it just tries to focus. I've looked through the settings as well to try to enable it so I guess either TouchWiz 'overrides' it or it hasn't been activated in the test firmware.
I don't see that functionality on JB on my CM10 device. Personally, I find ProCapture to be a much better camera.
Jelly bean is supposed to add a feature where you can swipe from right to left in the camera app to scroll through the pics you've taken. You can then discard those pics by swiping up/down, and finally you can "undo" pics that you've deleted to bring them back.
Running DLI7 and I can confirm its the bog standard touchwiz camera.
