Help camera settings
D
Deleted User
Guest
What are the best camera settings for sending photos via mms? I can use 8M down to VGA, but i'm having trouble sending them because of the size(i think that it may be the problem). Also, it may be because i used the HD setting. Thanks for any help.:confused:
To be honest, MMS is antiquated. File size limit is set by the Carrier. Best thing is to upload pics and vids to DropBox and then text a link.
i take pics at max resolution, and then when i send an MMS, it will automatically resize before sending it.
on a technical standpoint, i guess anything over 1-2 MB might not be allowed to send. take pictures at every quality setting and find out the file sizes of each quality that will fit your needs.
