Can anyone help with battery problem
Since been on 6.0.1 i had battery problems
i done a factory reset my phone still got batteru problems
i charge my phone 2 to 3 times a day
and i charge my phone to 100 before i sleep when i get up my phone battery drops from 100 to 60 percent
Is there anything i can do to fix the problems
Have you tried wiping the system cache partition? You've implied your battery problem started since the 6.0.1 upgrade so clearing the system cache is often a default task after every system upgrade. (A Factory Reset will wipe the user partition but not necessarily the system cache partition.)
Have you taken a look in your phone's Settings? Does anything stand out as odd in the 'Battery' category? Also, and this might be an indirect indicator of some app issue, is anything out of the ordinary in 'Data usage'?
I have deleted system cache i forgot to put that in as well i
This is what is using my battery
I turned off all the advanced features
