can i use a samsung charger for a droid razr
  • Start date Start date
A
Android Question
Guest
I have a droid rarer xt912 and was wondering if I can use the charger to charge a Samsung until my news droid RAZR xt912 ships in PLEASE HELP!!!!!!!!!!!!!!!
Hi, welcome to AndroidForums! :D
Well yes, ONLY if the pin socket is the same size. For example, I can charge my One S with a Galaxy S3 charger from my Galaxy S3. It will either work, or not work. It's a hit or miss, but you might want to buy a cheap aftermarket charger from eBay. Be careful with the voltages on a charger that's not for your phone. ;)
The total 'techie' answer is to double check the mAh output of the charger (should be 800-1000).
But the layman's answer is if the Samsung charger is for a smartphone, it should charge your Droid Razr just fine.
Oh, p.s., sorry to contradict a fellow staff member, but I wouldn't put much faith in cheap aftermarket chargers from eBay unless you know what you're doing; and even then . . . .
good luck
